CSCO10892433 Fri, 09/28/2007 - 00:30
Hi, J_Vansen_S
Only 802.3 frame uses MAC address; and a serial port is typically encaped by hdlc, ppp or frame-relay. All these types of frames don't use MAC address. So, you won't see the MAC address on a serial port.
SSLIN
GillieLucent Fri, 09/28/2007 - 11:17
Only LAN interfaces like ethernet, FDDI interfaces uses MAC address.
Serial interfaces don't use MAC address, since its directly connected to the peer.
In HDLC-like serial interfaces, the Address field is a single octet, which contains the binary sequence 11111111.
For more information,
read RFC 1661- The Point-to-Point Protocol
Vijaybabu
