2811 and VWIC-1MFT-E1
Sep 28th, 2007
i have a 2811 router with (C2800NM-ADVIPSERVICESK9-M), Version 12.4(15)T. I was intending to configure this E1 card for Data but it doesn't take me to the controller interface. what might be the problem? can this vwic do data?
gunner07971 Fri, 09/28/2007 - 02:46
Try the following,
Router(config)# card type e1 subslot
Then,
Router(config)#controller E1 port
Go on to configure the controller as usual followed by your serial interface.
Cheers,
paolo bevilacqua Fri, 09/28/2007 - 04:05
  • Hall of Fame,
    Founding Member
Actually, VWIC-xMFT-E1 does not need 'card type' command. Only the VWIC2 cards do need it.
