Richard Burts Fri, 09/28/2007 - 05:43
Marcio
The most simple and frequently best was to load share over 2 serial links is to configure 2 static default routes, one static default route pointing at each serial interface (or next hop address over the serial interface).
Rick
marcio.tormente Fri, 09/28/2007 - 05:52
Rick,
Thanks for your answer, but this not possible because that link go out for internet and need use NAT.
I tried this, but he did not function.
Do you have another sugestion?
Richard Burts Fri, 09/28/2007 - 06:07
Marcio
NAT does not need to intefere with using static default routes. What was the problem?
Rick
