Need a basic config for an 1841 to use ADSL?
whiteford
Has anyone managed to get an 1841 with the ADSL port to get on the Internet? I have connected but get no web pages.
Here are parts of the config I use:
ip dhcp pool client
import all
network 172.19.16.0 255.255.255.0
default-router 172.19.16.1
lease 0 2
interface ATM0
no ip address
no ip unreachables
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
cdp enable
interface FastEthernet0/0
ip address 172.19.16.1 255.255.255.0
no ip unreachables
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface Dialer1
ip address negotiated
no ip unreachables
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname 123456789@hg57.btclick.com
ppp chap password 0 123456789
ppp pap sent-username 123456789@hg57.btclick.com password 0 123456789
ppp ipcp dns request
ppp ipcp wins request
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source list 102 interface Dialer1 overload
access-list 102 permit ip 172.19.16.0 0.0.0.255 any
dialer-list 1 protocol ip permit
8 Replies 8
Danilo Dy
Try this link http://www.cisco.com/en/US/tech/tk175/tk15/tech_configuration_examples_list.html it has everything about ADSL whatever the router model you have.
Dandy
Thanks!
What I did notice was though if I ping from the routers console say www.google.com it would resolve successfully. From a laptop it won't but will if I put the IP of google's website in. I thought the import all option in DHCP would get the user to use the ISP's DNS servers?
In your laptop MS-DOS CLI, execute "ipconfig /all" and check if you have a DNS. If none, follow the guide to include the DNS in the DHCP.
Can you check also the output of "show ip dhcp import" from the router if it returns with a DNS entry?
Dandy
did you solve this issue I have the same problem
Hi, how far have you got, mines all working. All I had to do was add an Internet DNS server IP in the DHCP part.
Can you PC get onto Google by the IP, 72.14.207.99?
If so then its a simple DNS issue mentioned above.
Please rate this post
Man the issue looks very similar but instead a DNS ip address I just put this command on my internal interface ip tcp adjust-mss 1452 and this command on my dialer interface mtu 1492, then everything works!
Great, where did you get those settings from? It worries me that never set these mtu settings, everything works, but I wonder if things would be better if I did?
See link bellow! this issue is common when you have dls to internet and nat configured
This is very good link
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a7c2.shtml
