Lots or Retrans on access layer 2 from distrubtion layer 3
Sep 28th, 2007
We are currently using 3750's (non-E series)in the distribution layer 3 going to the access layer 2. We have noticed a lot of retrans issue on the access layer 2, 3750's, but no retrans in the same IP address range on the distribution layer 3, 3750's. The link between access and distribution are redundant dot1q trunks meshed. The issue still happens without the redundant meshed environment. Currently at 12.1(19). Has anyone else experienced this retrans issue and what was done to solve it.
jsivulka Thu, 10/04/2007 - 13:56
This issue is looking like Cisco bug (#CSCed00328) go throught it . What port is the server connected on and what is it's IP address.
Jeff.sadowski Fri, 10/05/2007 - 03:59
Thank you for this information on Cisco bug (CSCed00328). I also found this bug ID several days ago and open a TAC case with Cisco. We confirmed that this is the issue with the 3750's.
