hash on encryption key
Answered Question
Sep 28th, 2007
i have 20 ap's should the hashes match for each vlan on every access point.
1242AG
Correct Answer by dancampb about 9 years 9 months ago
It would depend on the type of encryption and authentication being used. If you are using a static WEP key then yes you would want to have the same encryption key associated to the same SSID on every AP. If you are using TKIP or AES or any type of EAP authentication then you would just specify the type of encryption since the keys are dynamically created.
Overall Rating: 2 (1 ratings)
Correct Answer
dancampb Sat, 09/29/2007 - 08:35
  • Cisco Employee,
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
