IP 7941 Call Answer
Sep 28th, 2007
When I have a call, I pick up the handset but the phone keeps ringing. I have to press the answer button after picking up the phone to answer the call. How can I answer the call just by picking up the phone without pressing answer? Also, when making a call I have to press new call first. I can't make a call just by picking up the handset. If I pick up the handest there is no dial tone, to get a dila tone I then have to press new call.
Rob Huffman Fri, 09/28/2007 - 08:08
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Alyn,
We had this trouble a few times with 7.x Firmware for 7941's and 7961's. This never happened again with 8.x Firmware;
bugid=CSCsc99161
Symptom:
Rarely a 7970 IP phone will get into a state where the speaker, headset, handset, or line buttons will not work to take the phone offhook. In this state the only way to go offhook will be to use the softkeys.
Conditions:
This has been seen in various Skinny phone loads up to and including 7.0(2)SR1. It is not dependant on CallManager version.
Workaround:
A simple IP phone reset will recover the phone.
Further Problem Description:
This problem can occur on Cisco IP Phone 7906/7911/7941/7961/7970/7971 independent of phone protocol (SCCP, SIP) and CallManager version.
Firmware 8.0(4)SR1 or later can resolve this problem.
Hope this helps!
Rob
