09-28-2007 08:12 AM - edited 03-14-2019 11:48 PM
We have a CCM 4.x in our lab, change site and the MOH of telephony stop of the play. I restart de TFTP and MOH Server but nothing!
We are using CISCO2801 like MGCP gateway.
Peterson
Solved! Go to Solution.
10-04-2007 11:09 AM
MoH by default does not support G729, but you can configure CallManager such that it can stream G.729 as well. To do this you need to go to Service Parameters for Ip Voice Media Streaming Application and for the field "Supported MOH Codecs ", check G729 along with G711.
Hope this helps
09-28-2007 08:15 AM
Did you change ip address on your callmanager ?
09-28-2007 08:18 AM
No it's same.
The ccm is tftp server too(lab)
The telephony is registered, the calls is ok.
I create a connection by ISDN by Siemens and the telephony "see" the telephony of Siemens side, but when I press hold button, only a beep sound.
09-28-2007 08:35 AM
make sure the MRGL, MRGs in use with the phones in question, have a MOH server listed.
09-28-2007 09:15 AM
09-28-2007 09:16 AM
09-28-2007 09:17 AM
10-04-2007 08:47 AM
I found the problem.
The MOH don't play in G.729, only in G.711.
I don't know why! The MOH Audio Source is ok to G.729.
10-04-2007 11:09 AM
Hope this helps
