available subnets
Sep 28th, 2007
I am confused by some of my study material. When calculating subnets I was taught it is minus 2 unless subnet zero is used and then minus 1 but the exam questions I am using seem to arbitrarily either use all subnets or subtract two - for exam purposes what should I assume the correct number to be?
NateBattle Fri, 09/28/2007 - 11:29
Always assume that subnet zero is not being used unless it explicitly that it is.
LucaSalvatore_2 Fri, 09/28/2007 - 17:43
subnet zero is enabled by default on most routers these days so i would say to assume that it is always being used unless stated that it is not....
sgregg Tue, 10/09/2007 - 09:58
Luca is right, now days all the IOS's seem to use subnet zero by default which is just the first subnet in your subnetted addresses. I would assume you use subnet zero unless the question specifically states otherwise.
