Warning message
MAC Address OID
Sep 28th, 2007
  • Bronze, 100 points or more
do the first 6 digits in the mac-address by Cisco, that indicate the vendor,
also indicate that the device is the same type of device?
Example is: if an ad-hoc network reported in AirDefense on a CiscoLinkSys
with 00-1a-70 as the first 6 digits, then I scan the wired side and find a
device (Hub) with the same beginning 6 digits, would this indicate it is a
same or similar model, or that just Cisco made the device.
dancampb Sat, 09/29/2007 - 08:39
  • Cisco Employee,
The OID will just let you know the vendor and not what the type of device is.
Trending Topics - Security & Network
