CSA - failed to compile the configuration (import related)
Sep 28th, 2007
  • Bronze, 100 points or more
I'm importing policies to a new 5.2 server from an older 4.5.1 server. When I attach these policies to a group and use them, I get this error:
The agent software failed to compile the configuration sent from the central server:
Iteration: 0
-- (000) 0010 00 00 00000000 .... ld #0
-- (001) 00a0 00 00 00000201 .... st M513
-- (002) 00a0 00 00 00000001 .... st M1
-- (003) 0010 00 00 00000000 .... ld #0
-- (004) 00a0 00 00 00000301 .... st M769
-- (005) 00a0 00 00 00000002 .... st M2
-- (006) 0010 00 00 00000000 .... ld #0
-- (007) 00a0 00 00 00000401 .... st M1025
-- (008) 00a0 00 00 00000003 .... st M3
-- (009) 0010 00 00 00000000 .... ld #0
-- (010) 00a0 00 00 00000501 .... st M1281
-- (011) 00a0 00 00 00000004 .... st M4
-- (012) 8c90 00 00 00944d48 RO.. ld M[']
-- (013) 28a0 00 00 00000602 .OA. st M1538
-- (014) 0c90 00 00 00000602 RO.. ld M1538
-- (015) 28a0 00 00 00000005 .OA. st M5
-- (016) 8c90 00 00 00944d48 RO.. ld M[']
-- (017) 28a0 00 00 00000702 .OA. st M1794
-- (018) 0c90 00 00 00000702 RO.. ld M1794
-- (019) 28a
I've tried exporting/importing different policies, different individual modules, etc. and this happens every time. Do I have to rewrite all these rules from scratch?
RichardSW Fri, 09/28/2007 - 13:42
Well I figured out what is causing this. I attached a single module to a policy, generated, polled, wait for the error - I narrowed it down to one module that contained API rules. They were looking for specific patterns in memory. I wonder if the pattern format changed from 4.5.1 to 5.2, and this compilation error is because of incompatible syntax.
Is anyone familiar with the API pattern syntax?
