How to disable manual time on Aironet 1231
bcolvin Sat, 09/29/2007 - 09:46
Once you are syncronized with your time server the manual field is filled with the current date and time. check under the time server address for the word Syncronized if you don't see it your AP has not been able to reach the time server.
also be sure to check the Event log configuration and select the time format. you will probably want to select local for the time stamp display.
good luck
Bill
bcolvin Mon, 10/01/2007 - 11:06
I am glad you were able to find a time server that the AP likes
Bill
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
