CSS certificate problems
Sep 28th, 2007
Hi, I installed and associated my cert on my CSS, but am having problems getting it working...
What I need is to be able to browse FROM my web server to a specific website which provided me with the cert 'myRSAcert' below. I have implemented the below but when I browse to the website it says I have no cert installed. I have not configured anything locally on the server, I have only configured on the CSS.
Here is what I have done on the CSS:
I have set up my 443 content rule:
content myContentRule443
vip address
port 443
add service ssl_test
I have added my service:
service ssl_test
type ssl-accel
slot 2
keepalive type none
add ssl-proxy-list ssl_list
I have added an ssl-server in my ssl_list:
ssl-server 50
ssl-server 50 vip
ssl-server 50 rsakey myRSAkey
ssl-server 50 rsacert myRSAcert
cipher rsa-with-rc4-128-md5 80
I have set up my 80 content rule:
content myContentRule80
vip address
port 80
add service server1
I have set up my internal web server:
service server1
keepalive type http
keepalive port 80
keepalive freq 6
protocol tcp
port 80
ip address
Am I correct in this general set up, or have I missed anything out?
Can anyone please help?
Overall Rating: 5 (1 ratings)
RODRGUTI Sat, 09/29/2007 - 15:15
Please add this command:
vip address
port 443
application ssl < -- add this
This command should make it work, if service server1 is alive.
If you do a http request on port 80, does it works?
- Rodrigo.
Gilles Dufour Sun, 09/30/2007 - 00:47
ok, ignore the other comment about application ssl. That's not required.
If I understand correctly the source of the traffic is
But from your config, this is also the destination.
Is this correct ?
If you want the browser to be able to open a connection to the vip, you need to configure client nat using a 'group'.
I can assist you with this if that's what you need.
But, if you want to do SSL initiation - the source sends cleartext request and the CSS encrypts everything before forwarding to a remote server, then your config is wrong.
Please, let us know what you need exactly.
cisco-pix Sun, 09/30/2007 - 03:18
I am looking to browse to a website ( from my local server ( My VIP is
In order for me to browse to this website I am required to have a cert, which I have requested and installed - myRSAcert.
Am I missing anything?
cisco-pix Mon, 10/01/2007 - 07:11
Hi, thanks for your help. I have looked through this and this is what I came up with:
1. Create a backend server, defining my Virtual backend ( and the Server I connect to externally (
ssl-proxy-list ssl_list1
backend-server 50
backend-server 50 type initiation
backend-server 50 ip address (INTERNAL - my virtual backend ssl server)
backend-server 50 server-ip (EXTERNAL - ip of the website I am looking to browse to)
backend-server 50 rsacert myRSAcert
backend-server 50 rsakey myRSAkey
2. Add an SSL service:
service myService1
type ssl-init
ip address
slot 2
keepalive type none
add ssl-proxy-list ssl_list1
3. Add a content rule:
owner ContentRules
content myContentRule1
add service myService1
vip address
protocol tcp
port 80
It still doesn't work, I am wondering am I missing anything else here?
Thanks so much for your help.
Gilles Dufour Tue, 10/02/2007 - 03:01
you also need to set the cipher:
backend-server 50 cipher rsa-with-rc4-128-sha
If that does not work after that,
get us a 'show summary' and 'show ssl statistics' before and after opening a connection.
Capture a trace on your server and a simultanous trace on the other side of the CSS.
