Additional VLAN on existing IPsec tunnel (ASA 5505)
Sep 28th, 2007
I have a LAN-to-LAN IPsec tunnel between the "VOIP" Vlans on two ASA 5505 boxes (Configuration is attached). Now, I would like to connect Vlan "Data1" on ASA1 with Vlan "Data2" on ASA2.
Unfortunately the attached config does not work, and after changing settings, I'm only able to ping between the VOIP vlans in one direction ? (from ASA2 to ASA1)
Any ideas ?
