What's the difference between Default route and static route?
Sep 28th, 2007
I wondered I read the the concept a lot of times, but I don't get it. Does someone could explain me detailed. Thanks a lot.
Overall Rating: 5 (5 ratings)
paul.matthews Sat, 09/29/2007 - 01:43
There is not a lot of detail to be honest. the two are quite different.
A default route is a route that will match ANYTHING - typically mask, That can be manually configured or generated by a routing protocol. An OSPF Totally Stubby Area will have an automatically generated default route.
A static route is one that has been manually configured. in a Cisco router that would be by emtering the command
ip route
In a routing table, the letter at the left identifies the source of the route. A static route will be identified by the letter S.
Most default routes will also be static, but that is not true the other way round.
Richard Burts Sat, 09/29/2007 - 08:16
I like the way that Paul explained default route in identifying 2 important characteristics of default route:
- a default route is a route that matches anything.
- a default route may be statically configured or may be advertised by a dynamic routing protocol.
I would add that the routing logic of IOS is to search the routing table for the most specific match. If there is no specific match and if there is a default route in the routing table then IOS will use the default route to make the forwarding decision.
I would suggest that there are equivalent characteristics of static routes:
- a static route is manually configured not dynamically learned.
- a static route may be a default route, or it may be a route to a supernet, to a specific network, to a specific subnet, or to a specific host.
Richard Burts Sat, 09/29/2007 - 13:14
Thank you for the compliment (and thank you for the rating). These are two important concepts and it is important to have a good understanding of each one.
