ajagadee Sat, 09/29/2007 - 08:53
  • Cisco Employee,
IPSG is not supported on the 2960 switches. DHCP Snooping is supported though.
I am not a marketing guy but if you want Catalyst Integration Security Features (CISF) such as DHCP Snooping, Dynamic ARP Inspection, IP Source Guard, PVLANs, then you should be looking at 3560 or 3750 switch.
I hope it helps.
Arul
** Please rate all helpful posts **
