Redundant or Parallel Routers?
Sep 29th, 2007
Hi! I am setting up a new network for a client. One Win DC, one Win File Srv & 8 PCs. ISP is ADSL. They will also use RDP. I am concerned about the router as the single point of failure. Can I setup two Cisco Small Business 107 Secure ADSL Routers. Put 4 PCs on one and 4PCs on the other? So in case of failure at least 4 PCs will connect until replacement. If so will I need two static IPs and two NICs on the DC? Is there a better similarly inexpensive solution?
Thanks in advance.
Overall Rating: 4 (2 ratings)
Rob Huffman Mon, 10/01/2007 - 11:39
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ken,
I just wanted to note that the Cisco Small Business 107 Secure ADSL Router is EoL. You may want to look at the much newer 800 seies ISR Routers :)
EOL/EOS for the Cisco SB 100 Series Small-Business Routers
http://www.cisco.com/en/US/products/ps6216/prod_eol_notice0900aecd805a5a93.html
Cisco 800 Series Routers
http://www.cisco.com/en/US/products/hw/routers/ps380/index.html
Hope this helps!
Rob
DeonLouwBotha Fri, 10/05/2007 - 11:17
Hi net100tec,
Look at the 800 Series as was mentioned in a previous post and take out SMARTnet on the ISR with 4 hour response, expensive but if failure is a worry and something does go wrong with the Router then the business will be offline for a maximum of 4 hours.
I am not familiar with the 107 routers and didn't see anything in the docs to show that they support HSRP, but it is an IOS router so it may. The recommendation to go to an 800 series is a good idea. They are cheap and have been pretty dependable. I run a handful for some remote locations running DMVPN over the internet. They also should support HSRP which would solve your problem nicely. You would configure both routers in a standby pair that shares a virtual IP address that you would use for you network default gateway. Check out the following for config info:
http://www.cisco.com/en/US/customer/products/ps6350/products_configuration_guide_chapter09186a008042fbb3.html
