vlan creation via snmp on 2106
Sep 29th, 2007
Dear all:
We need to create vlans on wireless controllers USING SNMP. While there is a detailed set of instructions on a similar subject for switches, the following are my difficulties:
1) The subtree of
SNMPv2-SMI::enterprises.9.9.46 is simply missing, I can't snmpwalk or snmpget anything under it. That corresponds to vlans on a 2950
switch, but we are on 2106.
Perhaps, since on these controllers
vlans are really dynamic interfaces, I should look under mib-2.system.interfaces? Well, I have, but there I encounter 2 problems:
a) interfaces.ifnumber == 8, which is the
number of physical ports on the thing.
Since I also have a management, apmanager
and virtual interfaces, this does not
seem to be it. (and it really looks like a
table of 8 rows).
b) Anyway, when I do an snmpwalk under the
mib-2, I get the error about oids not
increasing (I'll provide the relevant
output in the end of the message). Does
this mean the snmp agent on the device
is bad? Can I fix it myself? Is there
a way to compile additional mibs into it?
(I will neeed some level of detail here)?
IF-MIB::ifOutErrors.8 = Counter32: 0
IP-MIB::ipForwarding.0 = INTEGER: notForwarding(2)
IP-MIB::ipDefaultTTL.0 = INTEGER: 64
IP-MIB::ipInReceives.0 = Counter32: 7100
IP-MIB::ipInHdrErrors.0 = Counter32: 0
IP-MIB::ipInAddrErrors.0 = Counter32: 0
IP-MIB::ipForwDatagrams.0 = Counter32: 0
IP-MIB::ipInUnknownProtos.0 = Counter32: 0
IP-MIB::ipInDiscards.0 = Counter32: 0
IP-MIB::ipInDelivers.0 = Counter32: 3468
IP-MIB::ipOutRequests.0 = Counter32: 6866
IP-MIB::ipOutDiscards.0 = Counter32: 0
IP-MIB::ipOutNoRoutes.0 = Counter32: 0
IP-MIB::ipReasmTimeout.0 = INTEGER: 0
IP-MIB::ipReasmReqds.0 = Counter32: 0
IP-MIB::ipReasmOKs.0 = Counter32: 0
IP-MIB::ipReasmFails.0 = Counter32: 0
IP-MIB::ipFragOKs.0 = Counter32: 0
IP-MIB::ipFragFails.0 = Counter32: 7100
IP-MIB::ipFragCreates.0 = Counter32: 0
IP-MIB::ipAdEntAddr.102.1.1.10 = IpAddress: 10.1.1.102
IP-MIB::ipAdEntAddr.101.1.1.10 = IpAddress: 10.1.1.101
And at this point the walk terminates, since the OID's are not increasing.
These two are just the addresses of my management and ap-manager interfaces, so I
could just reassign them and hope they will
be increasing from that point on. :)))
BTW, the snmp object navigator on this site does not seem to find the last two.
Can someone, please, help me out here.
Thanks.
drolemc Fri, 10/05/2007 - 05:54
You cannot compile additional MIBs on to the device. And I don't think you can create dynamic interfaces on the Wireless LAN Controller using SNMP MIBs. You can create dynamic interfaces only through the CLI and the GUI on the device.
dgerenrot Tue, 10/09/2007 - 12:48
Thank you so much for your response. Please, forgive the late reply.
First, off, it does look quite impossible to compile additional MIBs into this WLC.
As far as creating wlan and vlan I have actually managed to do both. To create vlan:you use the table 1.3.6.1.4.1.14179.1.2.13.1 (Notice 1.4.1.14179 rather that 1.4.1.9 -- I think that's Aeronet's proprietary and cisco bought them). Anyway, the above OID is the interface table, you can actually see the management, p-manager and virtual interface under it. But the well-known problem with the snmpwalk prevented me from seeing any further (you get the OID not increasing error). I had to use some brute-force snmp get calls to get around that.
Before I go on any furhter let me set up some notation:
* IF_TABLE = 1.3.6.1.4.1.14179.1.2.13.1
* $Appdx() a numeric sequence
of the form L.c1.c2.c3...cL.
where L is the length of the word and
c1, c2 , etc are ascii encodings of
characters.
E.g., $oidAppendix('vlan3') == 5.118.108.97.110.51
Anyway, this $oidAppendix essentially behaves like an index.
So to set up an interface named vlan3: the
following seems to work:
Set 1.3.6.1.4.1.14179.1.2.13.1.31.$Appdx(vlan_name)
to 5 (Create and wait)
Notice the 31, that means RowStatus. (I assume the reader to be familiar with the SMIv2 tables)
Doing the above snmpset has the effect of initializing the row creation. Then you have to snmpSET the following:
IF_TABLE.1.$Appdx -- htat's interfaceName (String)
IT_TABLE.2.$Appdx -- interfaceNumber (int),
I think after this you can already see the
interface under Controller->Interfaces.
Next replace 2 by:
5 -- interface ip,
6 -- netmask, protected static final String
Etc. Here is the fragment of my java code:
CISCO_IF_GATEWAY = CISCO_IF_TABLE+".7";
protected static final String CISCO_IF_PORT= CISCO_IF_TABLE+".8";
protected static final String CISCO_IF_DHCP_PRIM = CISCO_IF_TABLE+".9";
protected static final String CISCO_IF_DHCP_SEC = CISCO_IF_TABLE+".10";
I vaguely recall not being able to
set these:
protected static final String CISCO_IF_ACTIVEPORT = CISCO_IF_TABLE+".15";
protected static final String CISCO_IF_QUARANTINE = CISCO_IF_TABLE+".17";
REMARK: The above is simply a sequence of set commands (and I could do it using v1 security no problem). Since I was using snmp4j java library I had to wait a couple of seconds between these set commands, else it did not work.
As for creating wlans, a single snmpset
operation works: to create wlan 4
use the table 1.3.6.1.4.1.9.9.512.1.1.1.1
(1.3.6.1.4.1.9.9.512.1.1.1.1.2 is rowstatus)
In a SINGLE snmpset operation, the following
works:
1.3.6.1.4.1.9.9.512.1.1.1.1.2.4 = 4; //4 -- create and go
1.3.6.1.4.1.9.9.512.1.1.1.1.3.4 = vlan4; 1.3.6.1.4.1.9.9.512.1.1.1.1.4.4 = vlan4_ssid;
Check the MIB descriptions for details
or email me at
stayonline dot net with the above uname.
dgerenrot Thu, 12/20/2007 - 16:58
Here is yet another important addendum. I wanted to add this for a while:
set 1.3.6.1.4.1.14179.2.1.1.1.42. to interfaceName (which is a string.)
This associates the dynamic interface interfaceName to the wlan
set 1.3.6.1.4.1.14179.2.1.1.1.6. to 1 (integer) This enables the wlan which is disabled by default.
Two more remarks:
1) These commands also work for Cisco 4402 AP controller.
2)setting 1.3.6.1.4.1.9.9.521.1.1.1.1.1. to 2 disables a certain security feature of the wlan called 'WPA' security. It's either that
or figuring out how to set the right security keys, etc., which we did not need for our project.
Trending Topics - Security & Network
