Unity Connection with remote sites
Answered Question
Sep 30th, 2007
What is the recommended way to configure Unity connection with remote sites? DSP resources are limited so would like to avoide transcoding if possible. Goal would be for local users to have system prompts/messages played in G.711 format, and remote sites to have system prompts/messages played in G.729 format without the need for DSP's to transcode. Is this possible? Or does Unity Connection only function with either G.729 or G.711 but not both?
thanks in advance,
Correct Answer by Rob Huffman about 9 years 9 months ago
Hi Daniel,
My understanding of this is that Unity Connection can support multiple codecs and avoid transcoding. Have a look;
To Change the Audio Format That Cisco Unity Connection Uses for Calls
Step 1 In Cisco Unity Connection Administration, expand Telephony Integrations, then click Port Group.
Step 2 On the Search Port Groups page, click the port group that belongs to the phone system integration for which you want to change the audio format of the media stream.
Step 3 On the Port Group Basics page, on the Edit menu, click Codec Advertising.
Step 4 On the Edit Codec Advertising page, click the up and down arrows to change the order of the codecs or to move codecs between the Advertised Codec box and the Unadvertised Codecs box.
If only one codec is in the Advertised Codecs box, Cisco Unity Connection will send the media stream in the that audio format. The phone system will transcode if it does not use this audio format.
If two or more codecs are in the Advertised Codecs box, Connection will advertise its preference for the first codec in the list but will send the media stream in the audio format from the list that the phone system selects.
Step 5 Click Save.
Step 6 (PIMG, TIMG, and SIP integrations only) If you want to change the packet size that is used by the advertised codecs, under Advertised Codec Settings, click the applicable packet setting for each codec and click Save.
Step 7 On the Port Group menu, click Search Port Groups.
Step 8 Repeat Step 2 through Step 7 for all remaining port groups that belong to the phone system integration for which you want to change the audio format of the media stream.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/administration/guide/2xcucsag140.html
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Sun, 09/30/2007 - 10:11
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Daniel,
Step 5 Click Save.
Hope this helps!
Rob
SBCdd7343 Sun, 09/30/2007 - 12:34
Thanks Rob. Appreciate the assistance today. Your awesome.
Rob Huffman Sun, 09/30/2007 - 13:23
  • Hall of Fame,
    Founding Member
Hi Daniel,
Thank you so much for your very kind words! There are many great people who participate in these forums but I've never considered myself one of them. We all try to help each other out and contribute to the completion of successful projects. Many people have helped me just like you will help many people. It's really a cool thing :)
Take care and Thanks!
Rob
