Abdulbaseer Mohammed Mon, 10/01/2007 - 13:18
  • Silver, 250 points or more
if its a same file you can use label and go to label for repeat. You can add one after anothe prompt and also check your prompt file properties it should work.
please rate if it helps,
Baseer.
vladimirbanker_2 Mon, 10/01/2007 - 21:57
no one of any of prompt file properties does not related to asynchronous playing.
In pseudo-code it should be like below:
-play prompt file asynchronous
-execute rmi java function
-stop playing file
as result customer listen prompt up to end of my function finish
Abdulbaseer Mohammed Wed, 10/03/2007 - 00:22
not sure if I follow. Not a true programmer but loook into what I said earlier.
Good luck.
Baseer.
