vg224 don't auto disconnect with analog phone
Sep 30th, 2007
Dear all ,
why vg224 don't auto disconnect with analog phone? is the busy frequency dismatch between vg224 and analog phone?
can you have any suggest to me ?
thks.
Anonymous (not verified) Fri, 10/05/2007 - 08:47
You need to configure supervisory disconnect under the voice port in VG224
gzmarketsl Sat, 10/06/2007 - 17:32
HI rrjoas45,
thks your answer, I try to add a command with supervisory . but I discovery it isn't effective . the port status follow:
sh voice port 2/0
Foreign Exchange Station 2/0 Slot is 2, Port is 0
Type of VoicePort is FXS
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 0 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 64 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 250 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 10 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Supervisory Disconnect Time Out is set to 750 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for CN
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Analog interface A-D gain offset = -3.0 dB
Analog interface D-A gain offset = -3.0 dB
FXS idle voltage set to high
Ring DC offset set to 0 volt
Station name None, Station number None
Translation profile (Incoming):
Translation profile (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Ring Frequency is 25 Hz
Hook Status is On Hook
Ring Active Status is inactive
Ring Ground Status is inactive
Tip Ground Status is active
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Hookflash-in Timing is set to max=1000 ms, min=150 ms
Hookflash-out Timing is set to 400 ms
No disconnect acknowledge
Ring Cadence is defined by CPTone Selection
Ring Cadence are [10 40] * 100 msec
Ringer Equivalence Number is set to 1
thks.
paolo bevilacqua Tue, 10/09/2007 - 16:12
  • Hall of Fame,
    Founding Member
Supervisory disconnect on the fxs ports doesn't make sense. What do you mean by "doesn't disconnects" ?
