kerek@banknet.net Sun, 09/30/2007 - 22:46
Try to search for FRF.12 for more information. If you imply to ppp fragmentation under "normal" fragmentation then the difference is the layer 2 protocol itself. The frame-relay fragmentation simply cut the longer frames to smaller in order to shorten the serialization delay (especially on slower links).
Hope it helps, rate if does
Krisztian
ashutosh_pateriya Sun, 09/30/2007 - 23:14
Hi Krisztian,
Thanks for yor reply. Well m y doubt is "how this FRF is diff from normal fragmeataion " . Both are chopping big frames into small ones to reduce delay.What role Framerelay is playing here.
