09-30-2007 10:00 PM - edited 03-03-2019 06:58 PM
How can i boot the Catalyst 4948 with New IOS which i am loading into bootflash.
I am setting the boot variable,but every time i reboot the switch it boots with the new IOS.
To get it boot with new IOS , i need to delete the old IOS from bootflash.
Boot variable i am setting is as follows
boot system flash bootflash:xyz.bin
09-30-2007 10:05 PM
Hi Satish,
As you mentioned "I am setting the boot variable,but every time i reboot the switch it boots with the new IOS" is it booting with new IOS or old IOS? May be its a typo error?
If it is booting from new IOS what exactly is a problem and what is your requirement?
The boot variable you are setting is correct and you can verify by using "sh boot" command.
Ankur
*Pls rate all helpfull post
09-30-2007 10:22 PM
Sorry yaa it was typo error...
I mean to say every time it boots with old IOS,even if i set it to boot with new IOS using above mentioned boot variable...
09-30-2007 10:25 PM
Hi Satish,
Can you paste the output of "dir bootflash:" and "show boot"?
Ankur
