Pix-vpn site-to-site
Sep 30th, 2007
I have a pix firewall with vpn configured recently. As the tunnel is not up i have enabled debug crypto isakmp and able to see the attached messages.
I have confirmed the pre-shared keys in both end and found same.
Please advice on where could be the problem. The other end firewall is not a pix which is configured with the same similar parameters.
Please help on this...
PIX Version 6.3(4)
Pix-506
regards
Rajesh
Overall Rating: 4.8 (4 ratings)
Jon Marshall Sun, 09/30/2007 - 23:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Rajesh
I appreciate that you have checked the keys but this message is the one seen when the keys do not match.
Could you change the key to something really simple like "test" just to make sure.
Jon
Sec IT Mon, 10/01/2007 - 01:56
Hi Jon,
I could see that the phase 1 is okay. Please find the attached show crypto isakmp sa and show crypto ipsec sa. And please suggest..
regards
Rajesh
ajagadee Mon, 10/01/2007 - 06:42
  • Cisco Employee,
Rajesh,
If you have already checked the pre shared keys on both the pixes, can you type "isakmp identity address" on the pixes and bring up the tunnel.
I hope it helps.
Arul
Sec IT Wed, 10/03/2007 - 00:05
Hi Arul,
Thanks for your reply.
Actually i have enabled the command "isakmp identity address".
You may find the below config too..
//user configured ACL
access-list 101 permit ip remote_local_subnet 255.255.255.0 user_local_subnet 255.255.255.0
access-list vpnacl permit ip host user_test_machine_ip remote_local_subnet 255.255.255.0
//ACL for vpn configured by me
access-list vpnacl permit ip remote_local_subnet 255.255.255.0 host user_test_machine_ip
nat (inside) 0 access-list vpnacl
access-group 101 in interface outside
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto map outside_map 20 ipsec-isakmp
crypto map outside_map 20 match address vpnacl
crypto map outside_map 20 set peer remote_ip
crypto map outside_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map interface outside
isakmp enable outside
isakmp key key123 address remote_ip netmask 255.255.255.255
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
Even i restarted my this end firewall after configuring the preshared key.
Pls let me know some tips...
regards
Rajesh
Jon Marshall Wed, 10/03/2007 - 00:15
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Rajesh
Could you
1) turn on the following debugging
debug crypto isa
debug crypto ipsec
2) Clear any existing Phase 1 & 2 connections for this VPN.
3) Try and initiate the connection and then post the output of the debug together with firewall config (minus any sensitive info).
Jon
Sec IT Wed, 10/03/2007 - 02:18
Hi Jon,
Please find the debug crypto isakmp sa and ipsec sa.
We had restarted both the end firewalls after giving the preshared key.
regards
Rajesh P
Jon Marshall Wed, 10/03/2007 - 02:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Rajesh
Coud you post configs of both firewalls or alternatively can you check the crypto map access-lists to make sure they agree on the local and remote subnets.
Jon
Sec IT Wed, 10/03/2007 - 02:56
Hi Jon,
Shall i send you tomorrow morning @ 10am.
since i have to go to the client place and send it.
regards
Rajesh
Jon Marshall Wed, 10/03/2007 - 03:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Rajesh
Yes that will be fine.
Jon
ajagadee Wed, 10/03/2007 - 06:14
  • Cisco Employee,
Rajesh,
Based on the debugs, the proxy identities are not matching, meaning the Crypto access-lists are not mirror images of each other.
Make sure that if you have a crypto acl on pix A:
access-list vpnacl permit ip 10.1.1.0 255.255.255.0 192.168.1.0 255.255.255.0
Then Remote Side Pix B:
access-list vpnacl permit ip 192.168.1.0 255.255.255.0 10.1.1.0 255.255.255.0
Arul
Jon Marshall Wed, 10/03/2007 - 06:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Arul
Agreed which is why i wanted to see the configs from both ends to make sure the local and remote networks match.
Jon
ajagadee Wed, 10/03/2007 - 07:07
  • Cisco Employee,
Got it John. You Rock :-)
Lets get this VPN Rock and Rollin for Rajesh.
Arul
Sec IT Thu, 10/04/2007 - 02:11
Hi Jon/Arul,
The scenario is like this. This end we use Pix firewall where as the other end its another vendor firewall where in there is no access lists configured for vpn specifically. Remote end firewall is basically GUI based, and i could not see any ACL configuration. I knew that both the end should have mirrored ACLs. Remote end has already two VPNs up and running and they want to configure one more. In the access list option i could see only one accesslist-button-check-box which is already checked and apart from that no options... I think i need to inform customer to configure the other end by his own with VPN-ACL. But client should not say how the other two Vpns are working without ACL..Unforunately i do not have the remote end config. Please find the attached config of thie end firewall
regards
Rajesh P
grahambartlett Thu, 10/04/2007 - 02:56
What was the spefic debug message that points to the ACL's not mirroring each other?
Jon Marshall Thu, 10/04/2007 - 03:03
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Graham
Basically the part about proxy identities ie.
IPSEC(validate_transform_proposal): proxy identities not supported
IPSEC(validate_proposal_request): proposal part #1,
(key eng. msg.) dest= remote_ip, src= this_ip,
dest_proxy= remote_local_subnet/255.255.255.0/0/0 (type=4),
src_proxy= user_local_subnet/255.255.255.0/0/0 (type=4),
protocol= ESP, transform= esp-3des esp-md5-hmac ,
lifedur= 0s and 0kb,
spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x24
For Phase 2 to complete both ends must agree on the local and remote networks they are encrypting traffic for.
Jon
Sec IT Fri, 10/05/2007 - 04:05
Hi All,
So, basically its a crypto ACL issue i hope..isn't it ?
regards
Rajesh P
Jon Marshall Fri, 10/05/2007 - 05:39
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Rajesh
It does look like it from the debugs you provided.
Jon
fallkaired Mon, 10/08/2007 - 00:21
Hi all,
Can someone help me please
An inside server (192.168.92.6) need to access to a remote network 192.168.31.0.
A VPN site to site is established between Pix outside (192.168.111.6) and Multitech Firewall (192.168.111.200).
Now my inside server should connect to the remote network with this IP 172.20.20.6. So I have to Nat my inside server IP (192.168.92.6) to 172.20.20.6.
The remote network should connect to inside network by the 172.20.20.6.
My problem is I can establish a connexion to my inside network from the remote network but I cannot establish connexion (tcp) from my inside network to the remote network.
The weird thing is I can ping from both network each other.
This is my config below
access-list Outside_1_cryptomap extended permit ip 172.20.20.0 255.255.255.0 192.168.31.0 255.255.255.0
access-list Inside_nat_static extended permit ip host I92.168.92.6 192.168.31.0 255.255.255.0
static (Inside,Outside) Ip_172.20.20.6 access-list Inside_nat_static dns
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map Outside_map 1 match address Outside_1_cryptomap
crypto map Outside_map 1 set pfs
crypto map Outside_map 1 set peer 192.168.111.200
crypto map Outside_map 1 set transform-set ESP-3DES-SHA
crypto map Outside_map interface Outside
crypto isakmp enable Outside
crypto isakmp policy 10
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
service-policy global_policy global
tunnel-group 192.168.111.200 type ipsec-l2l
tunnel-group 192.168.111.200 ipsec-attributes
pre-shared-key *
Thanks for answers
Sec IT Mon, 10/08/2007 - 22:28
Hi All,
vpn problem has been resolved. its an ACL issue (crypto)
Thanks for the support.
regards
Rajesh P
Jon Marshall Mon, 10/08/2007 - 22:31
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Rajesh
Glad to hear you got it working and thanks for letting us know the outcome.
Jon
