sysopt connection permit-vpn
Sep 30th, 2007
hi,
i have several site to site tunnels to many locations.
can i apply the command "sysopt connection permit-vpn" to one tunnel and leave it disabled for another tunnel ?
thank you
Overall Rating: 5 (1 ratings)
Jon Marshall Sun, 09/30/2007 - 23:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Joseph
As far as i know you cannot apply this per tunnel as it is a global configuration command
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/s8_72.html#wp1198155
All you do is for the tunnel you want to bypass the access-list on you need to permit all IP for that remote network in your acl.
Jon
