logging server ??
mohammad-yousef
Dear All,
I'm searching for a logging software to recieve logging messages from all Cisco devices (switches , routers , PIXs , IPS ..etc ), also able to recieve logs from Microsoft servers.
I need to know if theres a software that able to do that ? and how can I get it ??
Mohammad Yousef
steve.busby
Level 5
Level 5
Mohammad,
You have a lot of options on the market today. Everything from Cisco's CS-MARS, NetIQ (http://www.netiq.com/), LogRhythm (http://www.logrhythm.com/), Netcordia's Event Analysis (http://netcordia.com/products/netmri-event-analysis.asp) or you can simply build a Linux based syslog collector and use grep or Splunk.
Depending on your needs and budget, I would start with Gartner to find the top choices, then start contacting your reseller for demo's and trials. After you've test driven several, decide what works best for your organization, get it budgeted and implemented.
Steve
Danilo Dy
I use Kiwi Syslog Daemon Enterprise version USD159 http://www.kiwisyslog.com/
Dandy
Willard Dennis
We use ManageEngine's EventLog Analyzer
http://manageengine.adventnet.com/products/eventlog/index.html
It can accept regular syslog mssgs from Cisco devices, etc. as well as querying Windows machines for their event log data via WMI.
You can get a 30-day demo from them at the URL above.
Thanks alot for you all , I will check and try all the products you provided.
Thanks again for your help
