CUCM 5.0.4 security configuration fails
Oct 1st, 2007
I am building a CCM 5.0.4 server on a HP DL380, at the end of the initial build it fails at -
"security configuration fails(1)"
The server is the first server in the cluster and is connected to a 3550-24POE switch for it's FA ports on the server.
Has anyone came across this issues and if they have, what was there fix?
James
hadbou Fri, 10/05/2007 - 12:47
  • Bronze, 100 points or more
It looks like you have plugged the cable to ILO port instead of NIC.
JAMES WEST Mon, 03/24/2008 - 05:07
Yes l managed to resolve this in the end. It was a while ago, but l think my fix may have been plugging both eth0 & 1 NICs into a switch.
James
