Problem with Cisco Unified CRM Connector Server 3.0.2
Oct 1st, 2007
Perhaps someone could help me.
This application has been installed on a CRM 3.0 server (the 3.0.4 not seems to work well with CRM 3.0).
From a telephone device I can do a search for any name or phone number. My problem is that inside a contact or account when I choose either Dial or Info I get the following error:
Server Error in '/' Application.
Server was unable to process request.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.Services.Protocols.SoapException: Server was unable to process request.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[SoapException: Server was unable to process request.]
System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) +533462
System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) +204
C4LookupService.crm.CrmService.Retrieve(String entityName, Guid id, ColumnSetBase columnSet) +120
CTI.Cisco.CRMConnector.C4LookupService.WebForm1.Page_Load(Object sender, EventArgs e) +9015
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +47
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1061
Version Information: Microsoft .NET Framework Version:2.0.50727.832; ASP.NET Version:2.0.50727.832
What can I do from now?
Thanks for help
