10-01-2007 04:35 AM - edited 03-14-2019 11:49 PM
I've purused the docs for the appliance-based 5.1 Communications Manager and cannot find where/how to do backups (a.k.a. BARS). Is this still done via a LINUX BARS or is there some other utility? Thanks for the help.
Mike.
Solved! Go to Solution.
10-01-2007 04:46 AM
Hi Mike,
In CCM 5.x this is now called "Disaster Recovery System" pretty cool! Here is a look at the related info;
The Disaster Recovery System (DRS), which can be invoked from Cisco Unified CallManager 5.0 Administration, provides full data backup and restore capabilities for all servers in a Cisco Unified CallManager cluster. The Disaster Recovery System allows you to perform regularly scheduled automatic or user-invoked data backups. DRS supports only one backup schedule.
The Cisco Disaster Recovery System performs a cluster-level backup, which means that it collects backups for all servers in a Cisco Unified CallManager cluster to a central location and archives the backup data to physical storage device.
When performing a system data restoration, you can choose which nodes in the cluster you want to restore.
The Disaster Recovery System includes the following capabilities:
A user interface for performing backup and restore tasks.
A distributed system architecture for performing backup and restore functions.
Scheduled backups.
Archive backups to a physical tape drive or remote sftp server.
The Disaster Recovery System contains two key functions, Master Agent (MA) and Local Agent (LA). The Master Agent coordinates backup and restore activity with all the Local Agents.
The system automatically activates both the Master Agent and the Local Agent on all nodes in the cluster.
From this excellent doc;
Hope this helps!
Rob
10-01-2007 04:46 AM
Hi Mike,
Scheduled backups.
Hope this helps!
Rob
10-01-2007 05:06 AM
Rob,
You're the king!
Thanks for the quick response.
10-01-2007 05:10 AM
Hi Mike,
Ha Ha ! I wish (well not really) Thanks for your very kind words :) It's hard to keep up with all this stuff isn't it.
Keep up the good work!
Take care,
Rob
