Dialed number auto completion disappeared!
Oct 1st, 2007
After applying some SR's on my CCM 4.1, I have noticed, that the auto-completion functionality on the phones has disappeared. Earlier, when I had some number in the phone's Placed Calls history, for example 12345657, this number was auto-completed, after I have dialed 123. Does anybody know the cause of the disappearance?
Thank you!
dfokin Mon, 10/01/2007 - 22:16
But after some time the history appears again, but number completion does not work.
Tommer Catlin Tue, 10/02/2007 - 06:57
Possibly a firmware problem. Does it happen on all phones or just a few? If it is just a few phone I would factory reset them, then load the new firmware. If you still have issues, possibly CCM has an bug.
michaelmr Tue, 07/29/2014 - 07:53
Good morning,
Me too me this problem is happening
I have a problem with my Cisco 7940 phone, I do not work the auto-number, (Configuring Auto Complete Number), the firmware is: P00308010200 with SCCP protocol.
My Call Manager is: System version:
Before the autocomplete had numbers marked on the history of the phone.
For example, habbia call to 1234567 and the autocomplete function calls When I Scored 123 Showed That coincided cone is the pattern on the phone display.
Help me please.
Buenos dias,
A mi tambien me esta sucediendo este problema
Tengo un problema con mis telefonos Cisco 7940, no me funciona la opción de autocompletar el numero, ( Configuring Auto Complete Number ), el firmware es el siguiente: P00308010200 con protocolo SCCP.
Mi Call Manager es: System version:
Antes tenia la funcionalidad de autocompletar numeros marcados en el historial del telefono.
Por ejemplo, yo habbia llamado al 1234567 y con la funcion autocompletar cuando marcaba 123 me mostraba las llamadas que coincidian cone se patron en el display del telefono.
