Configure SRST on VG224
Hi friends,
i must configure SRST on VG224 that work as MGCP on CCM. I found some guide but they don't satisfied me. Someone can help me? my release is 12(4)6T7. I see that is possible to configure call-manager-fallback. I can configure it like a 28xx?
no one has got an answer?
To configure a VG224 to work with SRST, the configuration would be the same as you would configure a 2800 Series Router with MGCP.
2800 is in H323 but vg224 is in MGCP! is always the same?
Nopes, they would not be the same. MGCP Gateway and H323 Gateway configuration is different.
The following link has the configuration information you would need for the same.
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps2169/products_configuration_guide_chapter09186a00806674c3.html#wp1351962
