10-01-2007 07:02 AM
Hi folks!
can I load new mib into LMS2.6, in order to select the new mib Device Type into DCR?
Tks!!
Leonardo
10-01-2007 07:14 AM
Hi Leonardo,
LMS is pre-loaded with all MIB's required to manage the devices types it supports.
Is there a specific device type that you have concerns about? And if so, have you checked the supported device list to see if that device type is supported?
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_4_x/rme405/rme405.htm
(note, if they are supported in RME, they are supported in DCR)
-J
10-01-2007 07:33 AM
Thanks for your answer!
I have this kind of device
lc7500Chassis 1.3.6.1.4.1.2745.1.4.2.1
I didn't found it on RME supported devices, for that it will be good to load a new mib about this device.
But... it's impossible... right?
TKS
Leonardo
10-01-2007 08:13 AM
This is a LANCAST device (1.3.6.1.4.1.2745 is LANCAST). You cannot add support for this device to LMS. However, assuming it supports generic mibII objects, RME will do some basic inventory collection for it.
