Data Migration from LMS 2.5.1
Answered Question
Oct 1st, 2007
I want to know do you know do you need to stop the daemons manager before performing
NMSROOT\bin\perl dir1\wrapper.pl BKP
it doesn't says you don't according to the data migration documentation but it states you need to when performing the restore. Please let me know if I need to so I can determine on why i'm receiving errors toward the end of the backup.
Dion
Correct Answer by Joe Clarke about 9 years 6 months ago
No, you don't need to shutdown dmgtd before running the backup (only before running the restore). Looks like the permissions on the current files in your backup location are too restrictive. Try manually deleting all contents of E:\BKP, then run the backup again.
Overall Rating: 5 (2 ratings)
Correct Answer
Joe Clarke Mon, 10/01/2007 - 08:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
dionjiles Mon, 10/01/2007 - 11:47
I tried again and it gave me the same error, I am leaning toward going with a clean install and start from scratch. After talking with my colleagues a lot of things we don't want to back up due to we are currently using LMS 2.5.1 as a test environment. Once again Thanks for your help and I know I will posting more next week, I will be on LMS 3.0 :=)
