DID, CallManager, and Translation Patterns
Oct 1st, 2007
Here is my dilema, may be a simple fix or solution:
Running CallManager 3.3(5)sr2a (man we need to upgrade) and we have a remote gateway with a DID coming into it. The telco is passing the last 4 digits to us, we are translating these to an internal number (example 8345 to 6547). My problem is the outbound call is passing the translated number (6547). How to I setup a translation to pass the full number out the gateway? If I try to add a new translation with the numbers already used, CallManager complains the numbers are already in use in that partition/route filter. Hope this makes sense and TIA.
smahbub Fri, 10/05/2007 - 13:32
Try with one more translation patterns only for outgoing.
translation-rule 1
rule 1 ^6547 8345
dial-peer voice 10 voip
translate-outgoing called 1On Cisco CallManager, make a translation pattern and change the called party number from 6547 to 8345.
For more information on Tranlsation rule refer to Mapping Outbound VoIP Calls to Specific Digital Voice Ports and Mapping Outbound Calls to Unique FXS/FXO Ports on Analog Gateways.
