Cisco Secure Services Client
Oct 1st, 2007
Is there any way to get the Cisco Secure Services Client to only control my wired connections?
I do not need the supplicant for Wireless connections since that works as I want it and do not want to go through reconfiguring wireless on all the laptops in my organisation.
yjdabear Mon, 10/01/2007 - 10:51
  • Gold, 750 points or more
If you can live with the features offered by the built-in nonexpiring license that supports a basic wired-only feature set, just don't install the full wired and wireless licenses.
http://www.cisco.com/en/US/products/ps7034/products_qanda_item0900aecd80507fd8.shtml
"Q. What features are available in the nonexpiring, wired-only version of the Cisco Secure Services Client?
A. The following features are available in the nonexpiring, wired-only license:
? EAP methods
?EAP MSCHAPv2
?EAP TLS
?FAST
?GTC
? Smartcard support
? RSA SecureID support
? Wired adapters
? Support for standard RADIUS servers such as Cisco Secure ACS
? Central deployment of Microsoft Active Directory machine or use group policies"
tomasedwardsson Mon, 10/01/2007 - 13:45
Problem is that if I setup the wired only version, it still takes over my wireless configuration from windows.
ecaratti Wed, 10/03/2007 - 07:05
try with version 4.x. In my tests I found versions 4.1 and 4.2 stay away from wireless.
With 5.0 they bind to wifi adapter.
I think this happens because 5.0 has some kind of "full license with warning". If you try to use an unlicenced feature (on 5.0) it works but the client shows a warning popup. With 4.2 you can't configure an unlicensed feature...
Hope this helps.. :)
bye,
Emanuele
