10-01-2007 08:50 AM - last edited on 03-25-2019 07:10 PM by ciscomoderator
Hello
Someone knows a way in order to manage in simple way hour, dates, and holidays with IPCCX?
As an example using of the external ASP pages?
Tanks,
Alessandro
Solved! Go to Solution.
10-01-2007 01:13 PM
Alessandro,
it can be done multiple ways. If you only have app than just hardcoding dates is fastest and riskiest as well.
other options are call a holiday check file and have that point to an html file that has all holiday dates.
Attached are my two scripts that should give you good idea.
If it helps please rate.
Baseer.
10-01-2007 01:13 PM
Alessandro,
Baseer.
10-02-2007 08:07 AM
Hi Baseer
thank you very much for your help.
It helps me a lot.
Best regards.
