JORGE RODRIGUEZ Mon, 10/01/2007 - 09:43
  • Green, 3000 points or more
Keith, you need to allow through the IPsec ports udp 500, udp 4500 and protocol 50 esp.
create an inbound access list allowing these IPsect ports and apply acl to your outbound interface. Are you using Cisco vpn client on the windows machine? or are you using PPTP ? if using PPTP you need tcp 1723 and allow GRE protocol 47 .
Jorge
mikntwd49508 Mon, 10/01/2007 - 10:49
Can you give me an example of what the command parameters might look like?
like: 10 permit udp any any
JORGE RODRIGUEZ Mon, 10/01/2007 - 11:06
You can try :
access-list 101 permit udp any any eq 500 log
access-list 101 permit udp any any eq 4500 log
access-list 101 permit esp any any log
access-list 101 permit tcp any any eq 1723 log
access-list 101 permit gre any any log
apply acl-101 to outbound interface
access-group 101 in
if you want to be more especific with acl then create one specifying destination host.
mikntwd49508 Mon, 10/01/2007 - 10:57
The connection properties is created in Windows. As far as I know, Its suppose to be L2TP IPSec VPN connection. No Cisco VPN client software is being used.
JORGE RODRIGUEZ Mon, 10/01/2007 - 11:11
ok then omit in above acl udp 500, 4500 and esp protoco, if vpn clinent is the mricrosoft version it is the pptp.
