Relating to Active/Active Failover !
Oct 1st, 2007
In Active/Active Failover:
- If outside interface on Standby unit and on Active Unit of Admin Context are failed, what is the Status of this context on primary unit ?
(In my configuration, The status of Admin Context on primary unit is ACTIVE although outside interface is being failed.Is this wrong????? (I think the status of Admin Context on primary unit must be failed.)
I test this problem as following :
- Unplug outside interface of Admin context on primay unit -> Failover -> Admin Context is Active on Secondary Unit.
- After that, I unplug outside interface of Admin context on secondary unit, then I see that Failover occur but Admin Context on Primary Unit return Active Status (although outside interface is being unplugged).
Is this a problem ? How do you fix it ? (How do you configure ASA to make Admin Context must be failed on two unit when this situation happen ?)
Thanks alot !
(P/S: My ASA version is 8.02,the failover interface-policies are default) (Do anyone test with ASA version 7.2.x ?)
