10-01-2007 09:32 AM
With Ciscoworks 2000 ACS does not propagate access levels to Ciscoworks 2000 properly. I can login to Ciscoworks with my ACS username and Password so I do know ACS is working. Futhermore, In Common Services under the "security" tab it states, "Connection status is reachable and configured" for ACS within Ciscoworks 2000. Is there a patch needed for ACS, Ciscoworks or one of the suites within Cisco Works in order to have the two systems (Secure ACS and CW2000) to work together?
Our Server has:
Windows Server 2003
Common Services 3.0.5
LMS 2.6
DFM 2.0.6
CM 4.0.7
Thank you.
10-01-2007 11:32 AM
You can integrate ACS with LMS and each module within LMS.
There is no patch needed, you just need to follow the steps found at:
The link above is for LMS 2.5, but 2.6 has the same steps.
10-02-2007 06:19 AM
And by doing this nothing should go wrong with the CW2000 server? Reason I ask is because I am being told this was already done. Does this process need to be done everytime a new ACS version is installed or Ciscoworks patch is done in regard to its respective application?
10-02-2007 06:34 AM
you shouldn't need to change anything provided you are on a supported version of ACS
10-02-2007 07:23 AM
We are running ACS version 4.0
10-02-2007 09:40 AM
Yes, this will work....and you can patch servers without problem
Just make sure you don't upgrade to an unsupported version of ACS...for this check the release notes of ACS
