Cisco 2801 and DDNS, how?
Oct 1st, 2007
after several searches, i still cannot a solution to implement DDNS on the cisco router ios 12.4. it just does work with the hostname xxx.dyndns.org.
anyone managed to get it to work willing to share his experience and ddns config
thx
Overall Rating: 3 (1 ratings)
rsabapathee Tue, 10/02/2007 - 07:08
thanks. I got it to work partially through the following config. Note I replaced members.dyndns.org with 63.208.196.96.
ip ddns update method dyndns
http
add http://test:test@/nic/update?system=dyndns&hostname=&myip=
interval max 28 0 0 0
interface ethernet1
ip ddns update hostname test.dyndns.org
ip ddns update dyndns host 63.208.196.96
ip addr 192.168.1.1 255.255.255.0
The problem I now that is that the DDNS is updating the hostname with the internal ip address (i.e 192.168.1.1).
How to ensure that the WAN ip is matched to the hostname?
Note The Cisco 2801 is connected to the ADSL router through a Cisco Catalyst L2 switch.
Thx
rsabapathee Tue, 10/02/2007 - 08:51
what if i create a subinterface with no ip address??
anyone tried that?
paolo bevilacqua Wed, 10/03/2007 - 11:08
  • Hall of Fame,
    Founding Member
With which interface do you connect to ADSL? Your DDNS configuration must be put under that interface.
rsabapathee Tue, 10/02/2007 - 21:42
I created an interface this morning with no ip address but it does update the dydns record with the WAN ip address.
How to ensure that the WAN IP address is updated?
thx
