Making a backup of a catalyst 3550
Oct 1st, 2007
I'm new to this switch. The company has multiple 3550's for their VoIP and Video Conferencing. My question is this. How do I do a dump of the config. I would like to have all configs of all switches just in case that 1 breaks down and I have to replace it. Thx
Overall Rating: 5 (1 ratings)
Kevin Dorrell Mon, 10/01/2007 - 11:42
If you have a TFTP server on your network, then it is easy. Do a copy running-config tftp, and it will prompt you for the name of address of the server, and the file name.
To get the configuration back, do the minimum configuration by hand, then do copy tftp start, then reload the switch.
If using UNIX, make sure that the permissions are correct on the directory, otherwise it will not be able to create the file.
There are other options for the copy. Just try copy ?
Kevin Dorrell
Luxembourg
jacobss914 Tue, 10/02/2007 - 14:32
You can also copy a file that is in flash if you need a complete backup. Not sure why but hey IOS might be important to you also.
copy flash:"filename" or "Directory/filename" tftp
This is lot faster than uploading an IOS via a serial cable, even at 115200 baud.
And since you are new to this switch, nothing ruins your day faster than configing a switch, and not doing a copy run start.
I do a lot of my configs off line, copy tftp start ( copies my tftp file to startup-confg. Then I schedule the reload for down time at night.
Just remember copy (from) (to) so:
Copy run start - running-config overwrites startup-config
Copy run tftp - running-config writen to tftp server
IOS has recently taken on some really great features for config management. The root of these features is the "archive" global config command. Disclaimer: I've not done any testing with this command on the Cat platform and Cisco lists it as unsupported but they're in the code. Caveat emptor, YMMV etc etc.
Contextual Configuration Diff Utility
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080454f71.html
Configuraton Change Notification and Logging
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080454f73.html
Configuration Archive, Replace and Configuration Rollback
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080454f8c.html
Of course, there are some 3rd party products out there as well and I've used several (including free). I won't link them here but feel free to e-mail me if you have questions.
