10-01-2007 01:38 PM - edited 03-03-2019 06:59 PM
We are trying to understand the maximum number of T1 bundles can be made by use of MLFR feature on a channelised T3 card on a Enhanced Flexwan Module. Can anyone help us on that.
Anantha Subramanian Natarajan
10-05-2007 01:44 PM
Maximum number of links per bundle is 8
10-06-2007 06:19 PM
Thanks smahub
10-05-2007 02:51 PM
Not sure if it is less than what the enhanced pa does on the 7200:
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_data_sheet0900aecd8054951d.html
but you should be able to do for example 14 bundles w/ 2 links each, or less bundles of up to 12 links.
10-06-2007 06:19 PM
Hi p.bevilacqua,
Thanks for the reply and reference link. This limitation of 12 channels per bundle is for hardware processing or even to process on the software.
