Router's Tolerance to Vibrations and EM Fields
Oct 1st, 2007
Hello, one of our clients is building a datacenter very close to another datacenter they have, where Cisco routers are already working. They have to dig with drills and they are asking us about vibration tolerance levels and electromagnetic induced fields that the routers can support; in general, the recommendations and practices to take care of the equipment (i.e. Do the routers have to be turned off?, etc..).
I know this is a very open question so any information you can provide us will be welcomed.
Thank you very much.
arififtikhar Mon, 10/01/2007 - 21:52
Not sure about vibrations..haven't checked yet...but for EM field router doesn't affect much. The only affect that we could feel will be due to UTP/copper cables. If replaced by fibre could solve the problem.
adgoandaga Tue, 10/02/2007 - 05:39
I really aprecciate your response, i'm aware of the copper/fibre issue with EM noise generated but i'm looking for a bit more specific data.
Again, thank you for your help.
