Unity 5.0 Integration to CCM 5.1 - VM Port
eschulz Tue, 10/02/2007 - 07:52
This is expected behavior. The Enable/Disable flag only impacts whether or not Unity will use the port. It does not control the low level state of the interface between the port and the phone system.
eschulz Tue, 10/02/2007 - 10:14
Correct, that is the expected behavior. This is covered in the description for the Enabled checkbox. For example, http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/integration/cucm_sccp/guide/cuintcucmskinny060.html#wp1141651
"When the port is disabled, calls to the port get a ringing tone but are not answered."
This text also shows up in the Help file for the SA's System Ports page.
