IPSEC Site-to-Site Tunnel drops every 1hour
Oct 1st, 2007
hi guys,
need help on my ASA 5510 that establishes a site-to-site VPN tunnel to a Multitech Firewall.
The tunnel normally drops after an hour of connectivity and would reconnect automatically. The problem is I have a telnet application that connects to the other end of the tunnel that would end up also getting disconnected. If i do a consistent ping to a remote host on the other side of the VPN tunnel i would also get one "request timeout" when the tunnel drops.
below is my vpn config:
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
crypto map outside_ISP_map 1 match address outside_ISP_1_cryptomap
crypto map outside_ISP_map 1 set peer 207.224.XXX.XXX
crypto map outside_ISP_map 1 set transform-set ESP-3DES-MD5
crypto map outside_ISP_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO
crypto map outside_ISP_map interface outside_ISP
crypto isakmp identity address
crypto isakmp enable outside_ISP
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
no crypto isakmp nat-traversal
attached also is a screenshot of the Real-Time Log Viewer.
brianbono Mon, 10/01/2007 - 21:08
additional info:
asa001# sh isakmp sa detail
Active SA: 1
Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1 IKE Peer: 207.224.xxx.xxx
Type : L2L Role : initiator
Rekey : no State : MM_ACTIVE
Encrypt : 3des Hash : MD5
Auth : preshared Lifetime: 86400
Lifetime Remaining: 82985
asa001# sh isakmp stats
Global IKE Statistics
Active Tunnels: 1
Previous Tunnels: 668
In Octets: 919211
In Packets: 7753
In Drop Packets: 2241
In Notifys: 1342
In P2 Exchanges: 830
In P2 Exchange Invalids: 0
In P2 Exchange Rejects: 0
In P2 Sa Delete Requests: 37
Out Octets: 764348
Out Packets: 6411
Out Drop Packets: 21
Out Notifys: 1584
Out P2 Exchanges: 452
Out P2 Exchange Invalids: 0
Out P2 Exchange Rejects: 0
Out P2 Sa Delete Requests: 1156
Initiator Tunnels: 351
Initiator Fails: 9
Responder Fails: 4
System Capacity Fails: 0
Auth Fails: 2
Decrypt Fails: 0
Hash Valid Fails: 0
No Sa Fails: 0
russ Tue, 10/02/2007 - 06:20
Seems like the remote peer has negotiated a phase 2 liftime of 1 hour (3600 seconds). The default for the ASA is 8 hours (28,800 seconds) and 1 hour (3600 secs for a Cisco router). Both peers will negotiate the lowest lifetime value.
You'll need to reconfigure the remote peer's phase 2 liftime to match the ASA value of 8 hours, or increase both peer lifetimes, if you wish the tunnel to stay up longer.
"sh crypto ipsec sa" will display the phase 2 remaining sa lifetime.
russ Tue, 10/02/2007 - 06:33
Are you referring to the phase 1 lifetime or phase 2 lifetime value?
brianbono Tue, 10/02/2007 - 14:49
does my Global Timeouts set on the connection to 1hr had anything to do with the tunnel drops?
"timeout conn 1:00:00"
DIEGO ALONSO Wed, 10/03/2007 - 10:02
I am also having a similar experience between a PIX and an EdgeWater IAD router. Tunnel drops every day or two and takes 5-10 minutes to come back up. I don't have control over the EdgeWater device but would like to setup some kind of logging on my side to see if I can figure out what is going on. I tried "logging buffered debug" but that gives WAY too much info. Is there a way that I can have the output of "debug cry" type command go to a buffer to review it once a day or so?
brianbono Wed, 10/03/2007 - 15:23
hi guys,
I was able to solve this problem yesterday. All I did was to go to the remote vpn tab instead of the site-to-site vpn tab of my ASA to configure the Maximum Connect value under the default group policy. The reason for the was my site-to-site inherited that policy that says the tunnel can only be for 1hr and must reconnect in order to keep the tunnel. I have changed the settings now to unlimited and finally my vpn is working fine.
