IPS event log issue ?????
Oct 1st, 2007
I am install 4255 IPS in my network.
This IPS management and monitoring by VMS. every day huge log generate.
my question is where the log stored ? in VMS or IPS or Both. I want stored data last 15 days.
So how I remove event viwer(before 15 days) log from IPS or VMS.
Biplob
Overall Rating: 4 (1 ratings)
mherald Mon, 10/08/2007 - 20:36
You are still using VMS? Does VMS support IPS 6.x? If you do not use MARS/Security Manager, I would use the IPS Event Viewer Cisco has. IEV will handle up to 5 IPS sensors. IEV can store the logs locally and do some reporting/storing.
Mike
