CSC Trend Micro making problems
Oct 1st, 2007
i am using a sms client and i often get a error where it says connection to the server is lost. But when i shutdown CSC or disable HTTP scanning the error does not appear anymore. What can i do?
amritpatek Mon, 10/08/2007 - 08:40
  • Silver, 250 points or more
You can disable HTTP scanning as a workaround, however the more accurate solution will depend upon the error message you are getting in the CSC module and the client model you are using. Usually the message "connection to server lost" is because of delay in HTTP response. Following link may help you
http://www.cisco.com/en/US/docs/security/csc/csc62/administration/guide/csc8.html#wp1052518
