Connection failing on PIX 515 6.3(4)
Oct 2nd, 2007
Need some help here
Basically I have users coming in from the "clients" interface with Security level 0 and IP address 192.74.X.X/16 to a server on the dmz-client with security level 40 and ip address of 202.180.251.93/32 but the connection is failing even though there is an access-list allowing it from the "clients" interface, static (dmz-client, clients) and route configured. I have attached the PIX configuration and the failure logs as well.
Hope anyone can shed some light on this issue.
gfullage Tue, 10/02/2007 - 20:58
  • Cisco Employee,
Can't see anything obviously wrong in your config. Where did you say those error logs were? I'd like to see the syslog generated when this is refused.
