Cat3750: Change of Base Eth-MAC address?
d.wingert
Hello there,
I would just like to know if it is possible to change the Base Ethernet MAC address on a Cat 3750 and if so, how?
Dirk
2 Accepted Solutions
wdrootz
Level 4
Level 4
I think we can't change the base ethernet MAC address. In the fixed configuration Catalyst switches MAC addresses cannot be changed.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_qanda_item09186a00801b0971.shtml
ankbhasi
Hi Dirk,
No you cannot. Is there any specific requirement in your nrtwork which need to change base mac address?
Ankur
wdrootz
Level 4
Level 4
ankbhasi
Hi Dirk,
Ankur
Thank you both for your helpful replies!
Ankur: It's more a matter of interest than need. As I understand the Bridge ID is derived from the base MAC address of a switch. I was working on a lab scenario were I wanted to alter the choice of root bridge without making changes to any of the spanning-tree parameters.
Cheers, Dirk
