10-02-2007 02:20 AM
Hi, i have a working LNS terminating many connections and working successfully. I do have an issue with virtual-access interfaces (i have over 3000). It seems that interfaces are not removed and every time a user connects the number escalates with each new interface assigned. Is there a way to time out these interfaces?
Solved! Go to Solution.
10-02-2007 06:45 AM
Dan have a look at this document discussing per use ppp timeouts to unclone vaccess interfaces.
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_configuration_example09186a008009465d.shtml
HTH-Cheers,
Swaroop
10-02-2007 06:45 AM
HTH-Cheers,
Swaroop
